[Workbench] Mesh control far from boundaries
Old   July 5, 2016, 16:40
Default Mesh control far from boundaries
Beginner_CFX is on a distinguished road
Hello everyone
I need to add at the center of a volume, on a plane crossing the entire volume a height of volumetric elements finer than up and down. The plane doesn't exist in the gemometry, it is a location that I shose.
I want to have a kind of inflation but at the center of the volume, not at the boundaries.
Does someone can help me, please?
Thanks
Beginner_CFX is offline   Reply With Quote
Old   July 5, 2016, 19:03
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Well, in ICEM , you will still need to add a surface (plane) and give it the inflation you want. then declare it as interior when you export the mesh.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   July 6, 2016, 11:52
Thank you Ali,
Is IEM is the same like the mesh application when I am using "Fluid Mechanics (CFX)»?
I separated my geometry on 2 parts, I did Named selection from where I need fine mesh. In mesh application, I am trying to gather the 2 parts into only one. I am facing some difficulties. Can you give me some giddiness please?
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Ansys CFX exited with return code 1. dheelibun CFX 8 May 7, 2014 07:21
[ANSYS Meshing] Workbench 14: Mesh Control dstrunner ANSYS Meshing & Geometry 2 May 2, 2013 08:05
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
