August 2, 2016, 08:42 |
Blocking Strategy (Easy geometry)
Amet
Rep Power: 9 |
Hello friends,
I'm trying to learn icemcfd therefore forgive me for I ask easy questions. How should be block strategy for this geometry? I tried many things but when i do "Associate to curve", it was ridiculous. Thank you for tour reply |
August 2, 2016, 15:12 |
Daniel
Rep Power: 21 |
Well it's better going through some tutorials before starting ICEM CFD as it can be a little complicated at the beginning!
share the geometry if you can, I will try to help you mate if it's a 2D problem, then you can simply split block around the body and delete the inner block! |
[ICEM] O-grid around wing geometry | Anorky | ANSYS Meshing & Geometry | 15 | November 27, 2017 13:43 |
[ICEM] Blocking Strategy help required in meshing a half model aircraft (3D, UAV) | nikesh | ANSYS Meshing & Geometry | 1 | July 29, 2015 03:40 |
How to create boundary layer using ICEM cfd and using blocking meshing strategy | costy | Main CFD Forum | 0 | April 12, 2014 04:14 |
[ICEM] Blocking strategy for inclined plate | cbisw | ANSYS Meshing & Geometry | 3 | May 27, 2011 08:17 |
Blocking strategy | Twix | ANSYS Meshing & Geometry | 11 | June 28, 2010 12:09 |
