[DesignModeler] 2-D meshing for Fluent in Ansys 12
Like Tree3Likes
Old   September 7, 2009, 09:27
Default 2-D meshing for Fluent in Ansys 12
fade is on a distinguished road
Hi; our setup just got updated, and now there is no Gambit. I'm trying to make a relatively simple 2-D mesh, but I'm having a lot of trouble. I imported some coordinate points, and then used the DM 'design from points' command to create the lines. I tried creating surfaces, and then meshing them, but the mesher won't let me set boundary conditions or change materials, and Fluent reads in the mesh with negative volumes. Does anyone have any suggestions for how to make a 2-D mesh?
thanks a lot.
fade is offline   Reply With Quote
Old   September 8, 2009, 09:58
Default Analysis type = 2D
PSYMN's Avatar
Simon Pereira
On the right hand side of the project page (or by right clicking on geometry to get "properties"), make sure that "Advanced Geometry Options => Analysis type is set to 2D (default is 3D). Also, make sure that you made your model in the XY plane and Z = 0.
villager and japanese student like this.
Old   September 16, 2009, 17:16
Unhappy Geomety 2D in ANSYS 12.0
Abraham Jaimes Hernandez
Maldoror is on a distinguished road
hi.
I am working with ANSYS 12.0. I made a 2D geometry in the application DesignModeler, but when I load the geometry in the Meshing application, see "? geometry" in the outline tree.
How do I make a 2D geometry?
I do so that the geometry is identified by the Meshing application?
thank you.
Maldoror is offline   Reply With Quote
Old   September 17, 2009, 09:02
Default back on the project page.
PSYMN's Avatar
Simon Pereira
As I last said, go to the project page (before opening ANSYS Meshing), right click on the geometry field and select properties from the pulldown. On the right side a table of properties will pop up and you can make sure that Analysis type is set to 2D...
Simon
Old   September 17, 2009, 13:20
Thank you Simon.
Old   November 10, 2009, 12:58
Default Same trouble
kris
ksguntur is on a distinguished road
Hi
I was having the same trouble. I changed the analysis type to 2D but it still does not work. The mesher open and then closes. the error messages in the workbench window says "plugin error: no valid bodies found"
Can any one help please.
Thanks
Krishna.
ksguntur is offline   Reply With Quote
Old   November 10, 2009, 17:32
kris
Never Mind. I figured it out. Turns out I was doing it wrong.
Old   November 17, 2009, 12:13
kousis is on a distinguished road
to ksguntur:
i get the same thing. what were you doing wrong?
kousis is offline   Reply With Quote
Old   November 17, 2009, 12:15
kris
I was not actually creating the surface. I sketched it and tried to mesh it. I had to go to concept, create surface from sketch, generate and then try it. Make sure the analysis type is 2D.
m.najminoori likes this.
Old   November 17, 2009, 13:15
Thanks ksguntur!
Old   November 30, 2009, 03:30
dynamicdom is on a distinguished road
hey , my situation:
i made a surface in the desing modeler,meshed it as a 2d plate in the ansys 12 mesher .afterwards i wanted to set boundary conditions for in-/outlet of my streaming channel with a gasket in it.
the point is that i can't set boundary conditions for in-/and outlet.
where can i define inlet/outlet(just edges, because of 2d)?
hope anyone can help me...
regards
dynamicdom is offline   Reply With Quote
Old   November 30, 2009, 15:52
kingjewel1 is on a distinguished road
Originally Posted by dynamicdom View Post
hey , my situation:
regards
Define your Boundaries in the mesher first. As far as I remember CFX allows you to define them in Pre but fluent doesn't-
kingjewel1 is offline   Reply With Quote
Old   December 1, 2009, 00:15
Default Named Selections.
  #13
PSYMN's Avatar
Simon Pereira
Named selections are the key to CFD boundary conditions in workbench. This is the same for 2D or 3D, except that you apply them to edges instead of faces.
You can do it in DM or the ANSYS Meshing app.
Use the edge selection tool to select the edge (such as the inlet), then right click and choose the option for creating a named selection... name the selection "INLET" and generate...
Then repeat for other important ones. you don't need named selections for walls.
Simon
Old   December 2, 2009, 04:25
thank you two for your help!
Old   December 23, 2009, 12:40
just-right is on a distinguished road
Fluid Flow CASE (FLUENT) in the WORKBENCH
I tried the earlier mentioned tips, however I still get the error:
PlugIn Error: No Valid Bodies Found
I imported a sketch as *.CatPart (Catia V5) I generated a surface in DM. I tried it both with and without the imported sketch, both seem to fail. Any tips?
Thanks in advance
just-right is offline   Reply With Quote
Old   December 23, 2009, 22:49
Default Maybe you don't have things set to 2D?
  #16
PSYMN's Avatar
Simon Pereira
Are you sure you are setup for 2D? Look up in the thread for info about how to do that...
Old   December 24, 2009, 06:01
It seems the 2-D geometry should be placed on the XY plane. You can import an external geometry created on a different plane, just make sure you import it to the BASE plane XY.
Grid creation in v12 isn't what it should have been though.
Old   February 2, 2012, 23:13
Sean Quallen
SeanQuallen is on a distinguished road
Sorry to dig up an old thread, but I'm having this problem as well. I am using a 2D analysis and my surface/line bodies are in the x-y plane. In fact.. they open up in the meshing module and *then* I get the "PlugIn Error..." message. I can then close the message and continue on as if nothing ever happened. I carry on through the solver and I get results with it so I know it works, but I believe this is causing issues during a project wide update/parametric study.
Any ideas? I'm using 13.0 and I have a very simple airfoil/farfield geometrical setup. I drew it up in DesignModeler and created surfaces. This is driving me nuts so any help would be well appreciated!!
SeanQuallen is offline   Reply With Quote
Old   February 4, 2012, 15:19
PSYMN's Avatar
Simon Pereira
I am guessing that the error is what is stopping your parametric study...
You probably need to sort that out first...
CFD Online Users Survey
Old   August 20, 2012, 19:43
Jeff Freeman
jeff.freeman is on a distinguished road
Hi all, I'm new to Workbench (v13.0). I've spent hours trying to apply the suggestions made in this thread to my project, and still have problems. I hope somebody can explain what I'm doing wrong.
I have a text file of point data that is formatted appropriately for the Concept > 3D Curve tool. All of my points are are in the XY plane, with the Z values equal to 0. Marking the "Merge Topology?" option to "Yes", this gives me a Curve1 and single Line Body.
I then use the Concept > Surfaces From Edges tool to create a surface body from those edges. For some reason, I need to manually select all 9 edges from the Model View display. Selecting either the Line Body or the Curve1 from the Tree Outline does not work.
Now I have a Surf2 and a Surface Body, which I set to be a Fluid. After Generating and saving this geometry, I close DM.
Then I ensure that the Analysis Type is set to 2D.
After all of this, I still get the "PlugIn Error: No valid bodies found for 2D Analysis in part Part" error. Any ideas why?
The best reason I can imagine would involve DM only recognizing the 3D Curve as a 3d body, regardless of whether all the points are only in the XY plane.
-Jeff
Edit: I just tried suppressing the Line Body, and it worked! I loaded the geometry into Meshing and it didn't give me an error. Is what I did valid?
jeff.freeman is offline   Reply With Quote
2d meshing in ansys meshing syler3321 ANSYS Meshing & Geometry 10 November 1, 2012 20:42
How To save a created mesh file in Ansys Meshing ashtonJ CFX 4 January 7, 2012 22:04
Strange ANSYS Meshing 13.0 Problem brunob ANSYS Meshing & Geometry 3 June 21, 2011 20:03
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
[ANSYS Meshing] Ansys meshing with extended meshing jsm ANSYS Meshing & Geometry 6 January 10, 2011 12:09
