[GAMBIT] Modify geometry
Old   September 11, 2009, 14:46
Default Modify geometry
giacomo combariati
jackr84 is on a distinguished road
Hi,I have a problem. I must divide a muffler (there is a photo) in three parts:
inlet;
porous media;
outlet;
What command should I use? I thinked to do a section with a plane throught doing some vertexs on the face.Can i do this?
jackr84 is offline   Reply With Quote
Old   September 14, 2009, 01:32
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
If your geometry is still a real entity you just have to create a plane, and then split your volume with this plane.
If you have a virtual geometry, then it will be more complex
But nothing is impossible with Gambit...
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   September 15, 2009, 02:30
giacomo combariati
I have a virtual geometry, therefore the command is the same or it is another. Thank you.
Old   September 15, 2009, 05:19
-mAx-'s Avatar
Maxime Perelli
no, it is not so easy.
you may split edge with vertex
then choose the vertex and split the surface with the vertex, you become an edge which splits your surface.
you do this untill the perimeter of the surface which will split your volume is closed.
Once it is one, you create a surface from all the edges you needed to split surface.
And finally split volume with this wireframed surface
that's it.
After that you will master the split operations
Old   September 15, 2009, 08:16
giacomo combariati
ah ok, I'll do this, thank you!!!!
Old   September 15, 2009, 12:26
giacomo combariati
it is difficult because the geometry was imported.Can i create planes to split volume in three parts?
Old   September 15, 2009, 12:35
-mAx-'s Avatar
Maxime Perelli
it only works with real volumes.
what kind of import did you do?
with step I get real volume.
Else you only have 2 splits to do... the first one will be difficult because you don't know how to proceed (I explained you how to), but after it will be "easy"
In your case it is "difficult" because you have many surfaces, so you may try to merge the surfaces, it will just reduce the number of split operations, but you may decrease the surface quality.
Old   September 15, 2009, 12:54
giacomo combariati
I have a iges file,getted from a scanner 3d.can i modify the position of muffler?i would change the referiment system
Old   September 15, 2009, 13:40
-mAx-'s Avatar
Maxime Perelli
iges generates virtual geometry.
you can try to provide me the file (I am only tomorrow at the office, after i have holidays), I will try it out (either to convert it into step from proE, or to split your volumes but I need to know where)
Did you try to use the edges surrounding your volume for splitting? (just create wireframed surface from existing edges)
Old   September 16, 2009, 02:44
giacomo combariati
Hi, how do i send to you the file?
Old   September 16, 2009, 03:21
-mAx-'s Avatar
Maxime Perelli
check your private message
Importing CAD geometry and Editing edges to match Ahmed CFX 15 March 21, 2016 12:39
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
modify the geometry! RON CFX 3 June 2, 2003 13:30
