[ANSYS Meshing] ANSYS WB Mesher really slow?
Old   June 21, 2012, 10:32
Default ANSYS WB Mesher really slow?
peterputer is on a distinguished road
Hej,
i ve some questions regarding the speed of ANSYS WB Mesher. I just ve a Fluid Mesh of ca 200000Nodes and an Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz as processor and 8GB Ram.
So i know that CPU isnt the fastest around but still, it takes ca 5-10min to generate a Mesh which is pretty slow to my mind.
Am i using the wrong options?
My mesh is basically a 1° part of a 2 stage turbine rig, so it is a quasi 2D mesh.
I sweep the faces and use inflation layers and some mesh face sizings where i need it.
Regards
peterputer is offline   Reply With Quote
Old   June 21, 2012, 11:29
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I agree that ANSYS meshing is slow.
Far is offline   Reply With Quote
Old   October 13, 2013, 22:04
Petr Jurcicek
Peter023 is on a distinguished road
Hi Peterputer,
I've got similar problem when meshing a geometry using the sweep method for CFX pseudo 2D axisymmetric problem.
Is there any other solution to this problem? Could you suggest some other alternative meshers?
Thanks;
Peter
Peter023 is offline   Reply With Quote
Old   October 16, 2013, 07:44
vidyanand
Vidyanand Kesti is on a distinguished road
Yes ANSYS mesher is slow,Please check uncheck ature and proximity
or if it tet mesh use patch independent with incresing number of Cpu
Vidyanand Kesti is offline   Reply With Quote
[ANSYS Meshing] trying to mesh a saloon car in wind-tunnel with Ansys 13.0 Workbench mesher IvanCFD ANSYS Meshing & Geometry 10 July 8, 2014 15:55
Ansys Mesher too slow semo ANSYS 2 October 13, 2013 22:16
[ANSYS Meshing] Ansys mesher problem with multiple reference frame problem -cannot set as interior BC cfd1980 ANSYS Meshing & Geometry 1 November 22, 2011 12:25
Meshing problem with ansys default mesher wh88 ANSYS 5 October 5, 2011 16:27
Question about ANSYS Mesher and Global Min Size Setting jonny_b ANSYS Meshing & Geometry 4 April 11, 2011 10:05
