[ICEM] Problem on ICEM.
Old   October 2, 2009, 12:36
Default Problem on ICEM.
Eduardo
Eduardo is on a distinguished road
I am having a problem doing an hexahedral mesh using ICEM. It actually happen doing a modification of a previous successful mesh I constructed. Then I introduce additional edges to have more control while refining the mesh but then when I commanded the mesh to be built it was distorted. I notice that the vertices where the distortion was originated where marked red. In addition when I run the check/fix function it showed the following problem.
Any advice?
Regards,
Eduardo
Eduardo is offline   Reply With Quote
Old   October 5, 2009, 10:52
Default Distorted how?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I would be happy to help, but I can't see any attachment...
By default, I would suggest checking your associations to see if they are causing the trouble... Also check your distributions (at 12.1, the new split will inherit the distribution of its closest neighbor, but at 12.0 or older, you will need to copy the distribution to the new split edges).
You could also try the check fix function.
Simon
PSYMN is offline   Reply With Quote
Problem with 2D ICEM mesh check in fluent Nicola FLUENT 3 March 25, 2013 05:56
ICEM - Prism Tool Problem carpe85 CFX 0 February 10, 2009 12:25
ICEM CFD --- Spaceball problem Andrea CFX 2 May 23, 2007 23:43
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
