how to rebuild the geometry topology starting from the mesh.
Old   November 25, 2009, 19:46
Default how to rebuild the geometry topology starting from the mesh.
joegi
joegi.geo is on a distinguished road
I wonder if it is possible using icemcfd to rebuild the geometry topology starting from the mesh. For instance, I have a 3d mesh in plot3d format and I want to extract from it the geometry topology, is it possible to do this in icem cfd or ansys mesher?.
Cheers,
Joel
joegi.geo is offline   Reply With Quote
Old   December 1, 2009, 23:17
Default Mesh to Geometry.
PSYMN's Avatar
Simon Pereira
Yes.
If it is unstructured, you can use "edit => Mesh to Facets" and get some faceted geometry.
If it is structured mesh (most likely for plot3D), you can convert it directly to Bsplines with the same Edit menu. (Use Import Mesh to load the plot 3D file in the first place). Actually, you can also extract a blocking file from a structured mesh and modify that on your new geometry.
If it is unstructured and you have access to FE Modeler (in ANSYS Workbench), you can "skin it" and convert the skin to a Parasolid (Class A BSplines). This newer tool has much better geometry export capability.
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
virtual geometry richard FLUENT 4 January 7, 2009 05:16
changes in mesh topology Neil Main CFD Forum 0 March 27, 2003 10:44
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
