[GAMBIT] Need help regarding meshing in GAMBIT
Old   December 9, 2009, 17:23
Default Need help regarding meshing in GAMBIT
bhanu kiran susarla
bhanususarla is on a distinguished road
hi guys, i have a mesh with me which has 14400 cells. i would like to increase the number of cells to 28800 using gambit. are there any simple and direct tools to do this in gambit? thankyou.
bhanususarla is offline   Reply With Quote
Old   December 10, 2009, 00:56
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you cannot ask Gambit to reach a specific number of cells.
You can only set the element size.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   December 10, 2009, 05:24
mozaffar shekarchian
mozaffar is on a distinguished road
you can use Split Quad Meshes command to make quadrilatral face mshe elements into triangular one.
in this way you can increase your mesh size drastically.
I hope it will be useful.
mozaffar is offline   Reply With Quote
Old   December 10, 2009, 11:15
bhanu kiran susarla
thank you mozaffar, max
Gambit meshing error jx FLUENT 11 May 26, 2009 10:35
Gambit: too long meshing time! delsolman FLUENT 1 January 29, 2008 19:06
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 05:04
urgent help needed for meshing in GAMBIT chris FLUENT 0 September 5, 2002 09:18
