January 31, 2011, 18:47 |
How To Smooth 2D Surface
Ali
Rep Power: 15 |
I made a 3D curve using a given set of points in DesignModeler, but when I came to create a surface from the curve, the edges of the surface did not match up with the 3D curve. I tried messing with it and found an option that would fix the discretized edges, but I can't seem to find the option anymore.
I've been looking through the help files and I still can't seem to find it. Can anyone help me with this issue? I'm afraid the 'non-smooth' surface will create issues when running the simulations. I've attached a few pictures of the issues that I'm referring to. Thank you all in advance for your help. - Ali |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Validation of surface roughness model approaching a hydraulically smooth surface | jola | CFX | 1 | October 20, 2010 10:06 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
