[ Gambit ] How to "duplicate" nodes
Old   February 15, 2010, 11:51
Default [ Gambit ] How to "duplicate" nodes
Gearb0x is on a distinguished road
I have an edge with nodes created as I want (this edge is meshed with a boudary layer)
I would like to have the exactly same position of nodes for the edge in front of this one. How can I do that? Is there a way to copy/paste nodes?
I found a way to let gambit mesh a face without specifying nodes on all the edges but gambit doens't mesh it the way I want.
thanks for the help
Gearb0x is offline   Reply With Quote
Old   February 16, 2010, 01:31
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
In the edge meshing tool, click first on your previous edge (already meshed), and then on the other. Check if the option "Use first edge settings" is enabled.
It should work
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 16, 2010, 05:16
This was a good idea but this doesn't work because of the boudary layer...
Old   February 16, 2010, 05:43
-mAx-'s Avatar
Maxime Perelli
delete your BL, mesh your opposite edge, and re-create your BL
Old   February 16, 2010, 05:45
but the things is that I want it mesh as the boundary layer but I cannot put a BL there because it points in the wrong direction and I don't know how to change the direction of BL (the arrow gambits shows when creating one)
thnaks for the help!
Old   February 16, 2010, 06:54
-mAx-'s Avatar
Maxime Perelli
if you have a middle click on your mouse, you can use use it to switch BL-direction
Can GAMBIT edit element or nodes ? pongup FLUENT 2 July 8, 2008 08:32
Multiple hanging nodes in GAMBIT Partha Main CFD Forum 0 March 12, 2008 00:16
Gambit problem: reading the nodes Li FLUENT 2 June 10, 2004 13:20
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
