meshing the bed of a channel
Old   March 2, 2010, 10:47
Default meshing the bed of a channel
antonio is on a distinguished road
Hi all.
I am modeling a rectangular channel where the bed is composed of a triangular format.
I have used the Patch Independent Method. I pretend to refine the mesh near the bed. Which is the more effectively way of doing that?
I have tried to use the sphere of influence but i don`t think itīs a comfortable way of doing what I pretend. Any suggestions that might help me?
Best Regards.
antonio is offline   Reply With Quote
Old   March 2, 2010, 11:14
In conclude, actually what I want it`s to have more triangular elements near the bed in order to get the zone of higher gradients.
Regards
Old   March 3, 2010, 09:27
PSYMN's Avatar
Simon Pereira
You can right click on the mesh branch to insert sizing...
Just set a smaller size on the triangle surface. (change to the face picker and select the face).
Simon
Old   March 4, 2010, 10:42
Dear Simon:
Thanks a lot for your suggestion. I have followed what you mentioned but something really strange had happened.I have tried face sizing with 2 mm for the element size but when I click in the mesh branch I can`t see the body and neither the mesh .
These are the the main features of my problem:
The channel has 1.7 m in the longitudinal direction, 0.3 m of width and 0.14 m of height;
The bed consists of the contour of triangles (the base of the triangles "doesn`t exist") with 4.61 mm sides (just two sides). The space between the triangules is 1.54 mm. I pretend to have 3/4 tetra elements in the sides of this triangules.
My inputs at the moment are:
Min size = 6 mm;
Max Face Tet = 8 mm;
Mat Tet Size = 10 mm.
Do you know why this is happening?Any suggestions?
Best Regards
meshing triangular channel mu FLUENT 3 February 22, 2008 11:31
ANSYS CFX meshing bed of particles Tim Donohue CFX 1 November 11, 2007 05:44
help with meshing trapezoidal channel rosol FLUENT 0 September 14, 2007 03:26
tetrahedral meshing in square channel Aashutosh Magdum FLUENT 4 May 28, 2005 20:27
meshing Pebble bed using Gambit Maergaret FLUENT 2 February 16, 2003 10:16
