[GAMBIT] Gambit mesh around buildings
Old   March 4, 2010, 13:13
Thumbs down Gambit mesh around buildings
Rita
rcerdeira is on a distinguished road
Hi!
I am having some issues to built a mesh around buildings for a street canyon problem. I am following “Gambit tutorial 03 - simulation of wind around buildings”, but I am having some problems to mesh the volume just above the small domain with Cooper method.
I can mesh the small domain, but the top of the buildings are without a mesh and I don't know if this cause the problem. It simple doesn't create the mesh above the small domain... Cananybody help me?
Thank you in advance
rcerdeira is offline   Reply With Quote
Old   March 5, 2010, 01:19
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Try to split your domain along (xy) with y= top of buildings.
If you still have problem, split along (xz)
Meshing complex domain on the fly without any volume decomposition will fail most of time
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 5, 2010, 06:25
Rita
Thank you for your quick answer!
I have already my domain split, as in the image, but the buildings have different heights and the “small domain” is a little higher than the highest building... I am doing exactly what is told in the Gambit tutorial with some adaptations for my geometry. And worst of all, I am new at this...
Thank you once more
Old   March 5, 2010, 06:45
-mAx-'s Avatar
Maxime Perelli
Are you also giving the top of each building as source in the volume mesh panel (cooper mesh)?
Old   March 5, 2010, 09:32
Rita
Yes... The top of the buildings appear automatically in the face list of sources when I choose the small domain as the volume.
Old   March 5, 2010, 10:00
-mAx-'s Avatar
Maxime Perelli
are they meshed?
Then either you switch to tet-hexcore, or you want to work with "hexa", but in this case you need to split the domain at each building's height. You will have volume layers, but you should mesh them with cooper.
Else you can provide me your dbs file, and I will take a look at it on monday.
Old   March 5, 2010, 10:21
Rita
Could you do that really? So nice of you! I want to send you the file but it is too big to go as an attachment through here... Is there any other way? Anyway I will keep on trying, if I manage to make it I will tell you!
Thank you so much for your effort!
Old   March 5, 2010, 10:44
Rita
Following your advice I think the problem is solved ! I have changed to tet/hybrid elements with hex core (native) type and the mesh is ok! But on the pave I have quad and on the area above the small domain I have hex with cooper, do you think that can bring any problem?
Thank you so much!!!
Old   March 5, 2010, 14:31
-mAx-'s Avatar
Maxime Perelli
no problem with mixing hexa-tetra-pyramid-wedge.
Just check the skewness (over 0.95 you can have convergence problem, try to keep it under 0.9)
If you still want to send the file, upload it on a share server like rapidshare
Old   March 8, 2010, 04:40
Rita
Thank you very much for your help! For now I think it is not necessary to send you the file! But I am almost sure that I will post some more doubts further in time ...
Old   March 11, 2010, 07:24
Rita
Here I am again… Well, I have a small domain inside the domain. I have the small domain meshed and I am trying to mesh the pave of the domain. The idea is to have a less denser mesh. And that is the problem. I have made with size function, without, with different growth rate, different size limit and the mesh have always the same size, the size of the pave of the small domain... What can I do? Thank you
Old   March 11, 2010, 08:34
-mAx-'s Avatar
Maxime Perelli
size function with cooper, won't have a big effect on the volume, because this is just projection of sources along mappable surfaces (so the source faces will be projected (eg: the same), and consequently you cannot have refinement. At the other side, mappable surfaces can only contain mesh grading... but it is not refinement).
If you re-do what you did with tet-hexcore, you will see the difference
Old   March 11, 2010, 12:09
Rita
I have already done with tet-hexcore, but the problem is that I need a denser mesh near the buildings I think that with tet-hexcore it is not possible, is it? It doesn’t seem like.
Old   March 11, 2010, 13:34
-mAx-'s Avatar
Maxime Perelli
I don't understand what you want. The logic wants that your refine the mesh around the buildings.
post a picture or hand-sketch which explains what you want
Old   March 12, 2010, 04:31
Rita
Thats what I want, a refined mesh around the buildings. Is it possible with tet-hexcore mesh? Thanks again
Old   March 12, 2010, 04:52
-mAx-'s Avatar
Maxime Perelli
oh sorry I understood coarser instead of denser...
Sure it is possible with size function.
Mesh building faces as your wish, then create a size function (type meshed), and let grow the mesh (for instance with factor 1.2) till maximal cell size you want.
Old   March 27, 2010, 06:24
Jian
jackshao is on a distinguished road
Originally Posted by rcerdeira View Post
Hi!
where can i find “Gambit tutorial 03 - simulation of wind around buildings”? i haven't found this chapter in Gambit 2.2 tutorial.
jackshao is offline   Reply With Quote
Old   March 29, 2010, 04:40
Rita
I can send you, but I think that this is possible only by e-mail. Though the forum they just allow 97.7KB. I found this in another forum, but I don't remember which...
Old   April 5, 2010, 08:20
Jian
Rcerdeira,thank you very much! My email box is yunzhonghehit@126.com. Hope for your mail.
Old   April 16, 2010, 05:34
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Hey Guys,,
I have the same problem.. Can you send me “Gambit tutorial 03 - simulation of wind around buildings”? here is my email huget_teguh@ymail.com
Thanks
Teguh
Now Or Never!!!
teguhtf is offline   Reply With Quote
mesh, street canyon
How to set boundary layer of a moving body in GAMBIT to a mesh zone for dynamic mesh tomyangbath FLUENT 18 October 12, 2016 06:57
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 01:04
[Commercial meshers] Mesh import from gambit Kaushik Balakrishnan (Balakrishnan) OpenFOAM Meshing & Mesh Conversion 5 April 21, 2005 13:42
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
