Export the mesh to ParaView
Old   March 8, 2010, 13:56
Default Export the mesh to ParaView
antonio is on a distinguished road
Hi all.
Is it possible to export a mesh created in ANSYS-Meshing in order to see the mesh in another program like ParaView? What`s the process?If is not possible does anyone has another suggestion?
Regards
antonio is offline   Reply With Quote
Old   March 9, 2010, 03:42
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
My suggestion:
*if possible export your mesh as *.msh file (fluent)
*import and convert your model in OpenFOAM
*export the initial guess in VTK format
But it needs linux architecture for OpenFOAM
I am almost sure there is other ways, but this one works
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 9, 2010, 04:31
Max,
Thanks a lot for your suggestion. I´ll try to use the process you describe.
Best Regards
Old   March 9, 2010, 07:37
Max:
I did not read the Linux Part. I don`t have that. So I suppose that ParaView it`s the only way for me. Can you please say to me how to convert a *.msh file into a VTK format (I am using ANSYS meshing). ParaView also accepts this type of files (VTK).
Best Regards
Old   March 9, 2010, 08:08
-mAx-'s Avatar
Maxime Perelli
of course Paraview accepts VTK format, that's why I convert my FOAM files into VTK.
But without OpenFOAM, I don't know how
Old   March 14, 2010, 16:03
Default Cgns?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
ANSYS Meshing also exports CGNS format... Does that help? I guess there may be some license restrictions for some users though.
Simon
PSYMN is offline   Reply With Quote
Old   March 15, 2010, 13:38
Dear all:
I have tried to export my mesh because I was not able to see the mesh in ansys-meshing. I don`t know why but I have changed a little bit the geometry and know the mesh is " there" . In conclude, I don`t need any more to export my mesh.
Thanks to all.Best regards
Old   April 30, 2010, 11:25
Default Ansys result to Paraview
Julien Barbier
julien.24601 is on a distinguished road
Hi all,
this is for future reference for those that find this thread looking for a results conversion from Ansys to Paraview.
I tried converting a Model using the method stated above (export to Ensight). It worked once (2 million tet cells, Open channel flow). Since then never again.
We (thank you Michi), got it working by exporting to .cgns, then using CGNS with the added "cgns_to_vtk" script. This way it is not necessary to get OpenFoam. CGNS is run in a virtual machine with Linux.
(http://cgns.sourceforge.net/index.html)
Importing into Paraview was not a problem.
julien.24601 is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
2D mesh export of an original 3D model Yogendra Shastri Main CFD Forum 0 February 22, 2008 13:14
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
Patch mesh export ariorus OpenFOAM 3 March 7, 2006 05:41
