[DesignModeler] DM-how to create 1 part from 7 parts-7 bodies
Old   June 17, 2013, 14:41
Default DM-how to create 1 part from 7 parts-7 bodies
Moha
ahvz is on a distinguished road
In my case, I imported 7 parts-7 bodies into DM. when I am trying to convert the 7 parts to 1 part by "tools> form new part" , the form new part appears not active.
my geometry imported from solidworks also,
how to solve this ?
regards,
ahvz is offline   Reply With Quote
Old   June 17, 2013, 16:40
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
try boolean-» unite
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 17, 2013, 16:49
Moha
Solved!
thanks
Old   June 18, 2013, 22:47
Arthur Loginow
Maralady is on a distinguished road
How can I do the opposite? I would like to create several parts from just one part, I want to create interfaces and different cell zones
Maralady is offline   Reply With Quote
Old   June 18, 2013, 22:56
diamondx's Avatar
Ghazlani M. Ali
You need to slice then... use the slice feature
Regards,
Ali
Old   June 18, 2013, 22:58
Arthur Loginow
It works for 2D geometries?
Old   June 18, 2013, 23:12
Arthur Loginow
I was able to use the slice option, but I had to use the option lines from sketch to be able to then use slice with loops, is that ok? or I just made something wrong?
[DesignModeler] Can I keep some bodies freezed before meshing? yahya ANSYS Meshing & Geometry 4 December 3, 2012 11:32
How to create 2 separate Surface Bodies? Matlab69 FLUENT 5 April 22, 2012 14:53
[ICEM] Fluent skips parts i create in icem diamondx ANSYS Meshing & Geometry 14 April 17, 2012 14:48
[ICEM] Unique Parts option BrolY ANSYS Meshing & Geometry 2 April 11, 2011 03:33
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
