merged mesh
Old   April 13, 2010, 08:14
Default merged mesh
az_f is on a distinguished road
Hi All
I meshed two parts of my model separately in two different files using ICEM CFD with unstractured mesh and prism layer. When I want to merged these two parts in another file using merge volume mesh even with similar mesh size at interface I 've got multiple edges,Non-manifold vertices error at interface. Any idea?
Thanks
az_f is offline   Reply With Quote
Old   April 16, 2010, 12:29
Default Prisms are the problem...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You can't merge mesh once it has prisms... Tetra mesh is easy to manipulate for a merge, but prism makes things much more difficult... Once you merge, you can always run prism afterward...
For more on this merge function, I have described it in detail on several other CFD-Online discussions...
If you would rather just move forward from here, I suggest a non-conformal interface... Depending on your solver, this is done differently. CFX and Fluent both support non-conformal interfaces very well.
Simon
PSYMN is offline   Reply With Quote
Old   April 18, 2010, 08:14
Thanks Simon, I was wondering if I want to use a Part by Part mesh what should I do with interface? Another question is that the option existing mesh is really using the existing mesh pattern or it changes when we add the new part to geometry?
Thanks again
Old   April 21, 2010, 19:00
Default Behind the scenes...
PSYMN's Avatar
Simon Pereira
The interface just goes out at a named boundary and then you would set up the non-conformal interface in your solver...
Behind the scenes, the option to use existing mesh really just meshes the model as normal (Octree is still a top down method), but then replaces the octree surface mesh in the specified part(s) with the original mesh and then runs "Make Conformal" to make the volume mesh conformal with the surface mesh...
Simon
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
problem when converting mesh (made by ICEM) using fluentMeshToFoam Forrest_Lei OpenFOAM 11 October 16, 2009 06:28
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 13:47
