Link faces meshes for periodic BC with ANSYS WORKBENCH
Old   April 13, 2010, 10:28
Default Link face meshes for periodic BC with ANSYS WORKBENCH
mawi01 is on a distinguished road
Hello everybody !
I try to attach periodic BC to my geometry to receive an equal number of mesh elements on 4 specific surfaces. Usually, I used GAMBIT with its "link face meshes " function, which worked without any problems. Due to new version of ANSYS I am working with WORKBENCH (Physics Preference : CFD . Solver Preference : FLUENT) to mesh geometries. Unfortunatly, the ANSYS WORKBENCH doesn 't provide the function "link face meshes " anymore, which has been replaced by the "match control " function.
To simplify my geometry, consider it as an cuboid (or ashlar ? ). The front and back surface as well as both sides should be linked for periodic BC. Only the bottom and top surface remain as "walls". So , I used the "match control" function for the front and back surface and it worked. Next, I did the same for both side surfaces and an error occured telling me, that "The combination of different match controls causes conflicts. The conflicts will be at the intersection of the highlighted entities."
I have read through ANSYS Help to find a solution for my problem, but can't find a hint. I hope that you can solve my problem ! If you need more specific information just let me know !
Thank you very much!
Kind regards,
Martin
mawi01 is offline   Reply With Quote
Old   April 16, 2010, 14:56
Default Temporary Limitation...
PSYMN's Avatar
Simon Pereira
Sorry, this is a documented limitation at 12.1...
( see the help, 3rd bullet under "Keep the following information in mind when using the match control feature: " )
Sorry, we are working on it...
Old   February 1, 2011, 15:00
Default have you solved the problem?
wild
wildli is on a distinguished road
Simmon, have you solved the problem? I am encountering the same problem now. please let me know if your ansys has solved it or not, I am currently using ANSYS 12.0 and not sure if this version has the bug fixed or not.
thanks.
wildli is offline   Reply With Quote
Old   April 9, 2015, 16:42
nm
nvarma is on a distinguished road
and it still is a limitation?
nvarma is offline   Reply With Quote
Old   September 20, 2015, 16:46
Lightbulb Periodic boundary for multiple faces - ANSYS Meshing (Workbench14.5)
Joseph Kalyan Raj
JoeKal is on a distinguished road
There maybe a way to deal with this. In ANSYS Meshing, add a Symmetry object to ur main problem tree. In the symmetry option, insert Periodic. Now u can choose multiple faces for the periodic boundary on ur problem. Remember that the co-ordinate system needs to be cylindrical otherwise it will not work.
There is also a linear periodic option in the Symmetric option under Symmetry object. But I haven't explored this yet.
Hope this helps.
JoeKal is offline   Reply With Quote
Old   March 13, 2016, 13:10
Post
vlg
villager is on a distinguished road
Hope this helps.
As I found, Periodic and Cyclic Symmetry create rotated mesh, as for Rotational Periodic. Linear periodic creates a mesh that suits for Translational Periodic.
If the mesh contains two peridoic boundaries with the common edge that differ in translation direction, Symmetry would not help too. Checked in ANSYS v 162. There's still a limitation on mesh generation with multiple as it is pointed out in Meshing Help.
There same holds for Match Control.
Also to note, Match Control with Automatic/Tet Mesh did not worked for me in ANSYS v 162 at all - it creates mesh that causes "Number of nodes read (...) does not match number referenced (...). Resetting counter to match the number referenced." warning in FLUENT. Then the mesh quality is equal to 0, and skewness is 1, that results in impossibility of any solution. Mesh repair/improve does not help in this case too. I hope this bug would be fixed in next versions.
villager is offline   Reply With Quote
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 09:23
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
