May 5, 2010, 12:22 |
rotate a body
Eli
Rep Power: 16 |
I want to rotate a body 30º from the zxplane of the global coordinate system in designmodeler. Can someone help me? thanks |
May 20, 2010, 15:31 |
Body Operation
Simon Pereira
Rep Power: 47 |
This is probably a bit late, but it is tough to keep up with CFD-Online
You need to select the object, then go to Create (2nd menu next to File) and do a body operation. There are many types of operations, including mirror and rotate. You may first need to create an LCS if you don't already have a curve you can select for the axis of rotation... You should be able to figure out the rest from there. DM_Rotate_02.jpg |
Body in windtunnel - high preassure behind the body? | Andyjoe | OpenFOAM | 4 | February 16, 2010 10:57 |
Bluff body used for diffuser testing | lemat1 | Siemens | 0 | December 5, 2009 09:11 |
Body force at the cell face | Souviktor | Fluent UDF and Scheme Programming | 0 | March 31, 2009 08:54 |
oscillating body | fred | FLUENT | 1 | April 1, 2005 13:41 |
Inside, Outside or on the boundary of a Body? | AFP | Main CFD Forum | 2 | January 25, 2004 19:43 |
