[GAMBIT] error when open a file
Old   May 12, 2010, 10:41
Default error when open a file
bob12 is on a distinguished road
hi all
i have a problem with gambit. when i open a file .dbs gambit don't load and show me this message :
"unable to read format of database (version 2.4.4). the current format is version 2.3.14.
an error occured while opening the specified identifier. check if the database is already in use.
instead, opening the default identifier."
but i don't have change the version of gambit becouse i have used the same.
thank you
bob12 is offline   Reply With Quote
Old   May 17, 2010, 00:56
-mAx-'s Avatar
Maxime Perelli
it seems you are trying to open a database, saved from a newer version
Old   December 30, 2012, 16:36
Vishal Chauhan
vishu343 is on a distinguished road
HI, Actaully when your computer suddenly closed then there are two options, either a lok file is generated or your dbs file is saved in the lastly created scratch folder. You can find your dbs file in that folder...
vishu343 is offline   Reply With Quote
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
OpenFOAM13 for Mac OSX Darwin 104 hjasak OpenFOAM Installation 70 September 24, 2010 05:06
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
HELPInstallation on RedHat90 booosix OpenFOAM Installation 8 July 17, 2007 06:40
