May 30, 2010, 07:55 |
Who can mesh this step file ?
Vahid Memar
Rep Power: 16 |
Hi
Is any body here can mesh this step file ? I can not mesh this, after meshing the main face will be loss. please help me. |
May 31, 2010, 21:20 |
Is there more?
Simon Pereira
Rep Power: 47 |
You didn't really provide enough info to help you much (such as what was your problem and what kind of mesh do you even want?), but I was curious so I opened the file...
Should there be more than this? (is that what you meant by Face lost? Is something missing?) v_h_memar.jpg Is your problem that you have a bad model? Step is the second worst format out there (IGES is worse), if you output this from a CAD package, see if they can output ACIS (best for Gambit since it has an ACIS kernel) or Parasolid (Best for DesignModeler for similar reasons) If you output in a better format your downstream problems may go away Last edited by PSYMN; May 31, 2010 at 21:21. Reason: added line... |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
problems with STEP file | ertan | FLUENT | 0 | August 1, 2008 17:51 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
