June 10, 2010, 04:53 |
Turbogrid problem
I am using turbogrid to mesh an axial fan blade. I use Ansys bladegen to get the profiles for the blade from my cad and then export it into Turbogrid. When I bring it in it gives the following error: WARNING Profile 2 appears to run in the opposite direction from the profile before it. The order of profile points will be reversed. WARNING Profile 4 appears to run in the opposite direction from the profile before it. The order of profile points will be reversed. Does anyone know how to fix this? |
September 14, 2010, 10:43 |
How do you use Ansys bladegen to get the profiles for the blade? With the data import wizard? Have you tried attaching the CAD model of the blade to Design Modeler with the Blade Editor plugin and then transfering it to Turbogrid with ExportPoints feature? If yes, please tell me how you made it. Thanks! |
September 15, 2010, 06:38 |
Yes I chopped the blade up into sections in my CAD and used the data import wizard. Haven't tried the other method you suggested. |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Problem in Tutorial problem of fluent | Phanindra | FLUENT | 5 | April 17, 2007 09:57 |
some problem on using turbogrid. | Darcy Jiang | CFX | 6 | January 4, 2004 17:23 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
