[ICEM] how to expand block splitting
Old   June 21, 2010, 00:06
Default how to expand block splitting
ringtail is on a distinguished road
hello, everyone.
as following picture shows is the original block topology. But I want to expand the split through the vertex as the dash line displays.
I don't know if ICEM CFD has a function to realize the split. Any suggestion is welcome. I'm very appreciated for your help.
ringtail is offline   Reply With Quote
Old   June 21, 2010, 02:10
gajemon is on a distinguished road
Blocking -> Split Block -> Extend Split (near O-grid)
gajemon is offline   Reply With Quote
Old   June 21, 2010, 05:08
thanks for your reply. I have tried the extend split function, but it did not work. can you give me any detail information?
Old   June 21, 2010, 05:12
try
Extend Split -> All -> Apply
Old   June 21, 2010, 09:53
Default Gap?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
How did you create the blocks? Extend Split only works if the split was already implied. However, if you created your blocks bottom up there may actually be a gap between the vertex and the block below.
If you generate a mesh, is the number of elements between the top two edges and the bottom edge tied together?
If not, there is a merge option to merge a vertex to an edge... Then extend the split.
PSYMN is offline   Reply With Quote
Old   June 21, 2010, 10:37
i see, thanks for replies.
flux splitting emrah Main CFD Forum 3 August 30, 2014 08:53
Flux splitting Dr B.M. Smith (Smith) OpenFOAM Running, Solving & CFD 19 January 9, 2013 04:07
Flux splitting for WENO scheme DSS Main CFD Forum 6 January 10, 2007 10:59
Time splitting in DNS fan Main CFD Forum 0 May 12, 2003 19:52
Flux vector splitting of Inflow/outflow BC Quain Tchew Main CFD Forum 4 March 25, 2002 19:43
