July 1, 2010, 07:10 |
virtual faces, volumes creating problems
amber
Rep Power: 15 |
hiii all
i imported step file from pro/e to gambit,it resulted in creation of many virtual edges faces,volumes.I basically have to subtract the geometry from the outer cube but i am unable to merge faces,volumes on the geometry[the virtual faces are the main problem].Also there are about 60 faces and the method seems quite cumbersome.any suggestions?? |
July 2, 2010, 02:13 |
Maxime Perelli
Rep Power: 41 |
step file import, should generate real geometry. (in my case with ProE Wildfire 3)
Are also getting real geometry just after the import?
In memory of my friend Hervé: CFD engineer & freerider |
July 2, 2010, 09:18 |
Try ACIS.
Simon Pereira
Rep Power: 47 |
You could also try exporting an ACIS (*.sat) file from Pro/E.
Generally speaking, STEP and IGES are two worst (sloppy) neutral formats available and every CAD vendor has their own flavor. ACIS, on the other hand, is standardized and higher quality.. Also, Gambit is built on an ACIS geometry kernel, so it should work a little better (one less translation). |
July 2, 2010, 09:57 |
#4 | |
Maxime Perelli
Rep Power: 41 |
CAD model sliver faces - CFX Mesh - Parasolid? | Ianto | CFX | 3 | February 8, 2009 18:32 |
Could you please help me about the VTKFoam | liugx212 | OpenFOAM Pre-Processing | 5 | February 13, 2008 11:31 |
OpenFoam 14 installation problem | gfcoppola | OpenFOAM Installation | 20 | November 2, 2007 13:38 |
[OpenFOAM] Could you please help me | liugx212 | ParaView | 4 | December 22, 2005 16:55 |
Gambit - Virtual Geometries (Pro's & Con's) | James Date | FLUENT | 3 | August 11, 2003 15:46 |
