July 13, 2010, 20:30 |
Immersed objects
Yarzar
HI,
I need help in modeling bodies in fluid volume. I used gambit before and all I had to do was subtract the object from the fluid domain. Now, I am using ANSYS workbench 12.1. I tried the enclosure command but I am not so sure how it works. How could I make the object hollow and the domain meshed ? Thank you |
July 14, 2010, 06:30 |
Matthias Voß
Rep Power: 20 |
hi,
use the boolean body operation (subtract) after freezing everything. before that you have to create your exterior and your body-to-subtract. you also can slice a body by other bodies, ending up in lot of bodies and then just simply delete everything you don´t need (body operation delete). neewbie |
July 15, 2010, 14:36 |
Yarzar
Thank you very much !
July 15, 2010, 20:52 |
Join/union or MultiBody Part?
Simon Pereira
Rep Power: 47 |
Debashish,
Do you want to join two bodies into a single body or make a multi-body part so they are still meshed as two bodies, but with conformal mesh where they meet? Simon |
July 14, 2010, 13:28 |
Multibody
Debashish Saha
I am a new user of Ansys and I need to know how can I join tow body in 3D? I knew how to do that in SOLIDWORKS but here it does not work in that way. Can anyone please help me? Regards, Debashish |
IcePak network objects in parallel solver | Alexey | FLUENT | 1 | December 25, 2013 08:32 |
Rigid Body State Variables in Solid Immersed Simulation | Hamidreza | CFX | 1 | October 19, 2009 06:14 |
Warning when I add my objects | Xu | Phoenics | 0 | November 21, 2008 12:30 |
Immersed Boundary Conditions | Mahibooswami | Main CFD Forum | 2 | June 19, 2003 19:10 |
immersed boundary method with unstructured mesh | x.zhang | Main CFD Forum | 0 | August 25, 2002 21:57 |
