[GAMBIT] gambit global geometric tolerance
Old   July 17, 2010, 01:53
Question gambit global geometric tolerance
alireza
alireza2475 is on a distinguished road
i am modeling a micro geometry in the gambit.
when i want to mesh a face, gambit warns me as:
mesh size on face *** is smaller than geometric tolerance ....
i Know that the default global geometric tolerance of gambit is 1e-6 and the solution of this problem is to define it in a larger scale like mm.
but i can not change the scale, the geometry is so complicated and i cant really model it again.
i want to know if there is any way to change the global geometric tolerance in Gambit to some thing like 1e-7 ?
Help me please.
thank u.
alireza2475 is offline   Reply With Quote
Old   July 19, 2010, 01:23
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Gambit has no unity.
If you are working in micro-m, then multiply all your geometry with factor 1e6.
For instance if you have a cylinder with radius 10 mu-m with an height of 100, thje create a cylinder 10x100.
You will need to scale your geometry in the solver, but later and independant to gambit
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
GAMBIT - warn about geometric tolerance CFDNewbie FLUENT 2 July 7, 2007 09:48
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
