[ANSYS Meshing] Different refinement zones on same part?
Old   October 17, 2014, 07:57
Default Different refinement zones on same part?
Jacob
smartsoldier is on a distinguished road
I need to know how to create different refinement zones on a single part. Not that they simply need to transition from coarse to fine, but that the cells need to abruptly change size as if I was using a mesh interface. I tried to show what I mean in the attachment, in which some of the finer grid lines in the bottom piece simply dead-end into the upper less fine piece, but are still the same overall part. I know this is possible in ICEM but I cannot seem to figure out how to do it in ANSYS Meshing. Thanks a lot.
smartsoldier is offline   Reply With Quote
Old   October 19, 2014, 08:31
Jacob
Come on guys I really need some help here
Old   October 20, 2014, 01:27
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hey Jacob
I think if you want to create a grid exactly like the pic, you must split the domain to 2 separate domains! with coarse and fine meshes!
and if you want to have 1 domain with a grid exactly like your pic, it's impossible!
in 1 domain, you can only create a coarse grid at top that turn to fine mesh at bottom with using "bias factor"!
amin.z is offline   Reply With Quote
Old   October 20, 2014, 17:52
Jacob
Alright thanks, I already know about bias factor but it doesn't perform very well in my specific situation. How can I split the part up into multiple domains? Can I do it within the meshing window, or do I need to go back to geometry and carve out multiple areas?
Old   October 27, 2014, 10:12
amin.z's Avatar
Amin
I think it's a type of non-conformal mesh! So you will need change your domain to 2 fully seperate domain!
Old   October 27, 2014, 10:22
amin.z's Avatar
Amin
You cann't seperate its in Ansys meshing! You will need back to design modeler!
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 09:30
[CAD formats] how to call my .stl file in the terminal izna OpenFOAM Meshing & Mesh Conversion 21 July 9, 2013 16:17
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
[snappyHexMesh] Weird snapping outside a refinement region jasimpson89 OpenFOAM Meshing & Mesh Conversion 0 July 29, 2012 20:46
