[ICEM] Weird legend
Old   August 3, 2010, 09:52
Default Weird legend
AB
BrolY will become famous soon enough
Hi guys,
I attached a picture which shows weird "blocks" around the vertices. Some are bigger than others. Does someone know what does it mean, and where does it come from ?
Thanks for your help,
AB
BrolY is offline   Reply With Quote
Old   August 4, 2010, 10:03
Matthias Voß
mvoss is on a distinguished road
did you do some splitting on those edges?
neewbie
mvoss is offline   Reply With Quote
Old   August 4, 2010, 10:44
Default Edge Splits.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Newbie will have to change his name... He is not a newbie anymore...
But yes, those are edge splits. You could move them or remove them. They help control edge curvature, but you don't really need them here (straight edge).
I notice that your sharp feature edge that has these edge splits is only surface associated, you should probably associate that edge to the curve... Always associate edges to curves if you have them...
Simon
PSYMN is offline   Reply With Quote
Old   August 5, 2010, 04:24
AB
Thanks ! I used the option "remove splits" to delete those "boxes".
CFX post legend modification mactech001 CFX 3 December 25, 2011 22:12
Weird problems running unsteady braennstroem OpenFOAM Running, Solving & CFD 5 June 8, 2011 20:38
legend values in cfx-post potac CFX 0 February 11, 2010 02:29
changing legend in FLUENT ak6g08 FLUENT 3 February 10, 2010 12:26
Weird pathlines on periodic sides maxime FLUENT 0 June 13, 2007 12:01
