wall shadow
Old   August 13, 2010, 03:09
Post wall shadow
abhay
rage is on a distinguished road
i made a geomtry in gambit and exported it to fluent, while giving boundary conditions in fluent, it is showing me wall shadow for some of the walls. what does it mean? have i made some mistake in drawing geometry.
Thanks in advance for the help
rage is offline   Reply With Quote
Old   August 15, 2010, 17:36
Wink Don't be afraid of the shadows
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Hey Rage, with a name like that, you may not be starting out with enough patience for CFD
As for wall shadows, Fluent does that automatically for internal walls so it can distinguish between the shells attached to the volume element on one side vs the shell on the the volume element on the other side... It basically makes a copy of the internal wall and fixes the connections (or splits the internal wall if you would rather look at it that way). It is a good thing and you don't need to worry about it.
If you were planning to set a thermal boco or something on that internal wall, you will need to set it to both the wall and its shadow...
PSYMN is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
wall shadow problem paul FLUENT 5 November 16, 2013 13:46
wall shadow amar FLUENT 1 February 5, 2010 06:07
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
