[ICEM] Quality/Determinant
Old   August 29, 2010, 21:55
Default Quality/Determinant
Przemek
Batis is on a distinguished road
In ICEM documentation there is written that, for Hexa elements: "The quality is calculated as the Determinant, as described in Determinant (2x2x2 stencil)". But, fo my case, the parameter evaluations are different. Sobebody has an idea, why?
Thanks,
Batis
Batis is offline   Reply With Quote
Old   January 21, 2011, 11:29
Default Hexa Quality
John
josilver is on a distinguished road
Originally Posted by Batis View Post
Thanks,
Batis
The quality is a weighted diagnostic between Determinant (between -1 and 1), Max Orthogls (normalized between -1 and 1; if deviation from orthogonality is greater than 90 degrees, then the normalized value will be smaller than 0) and Max Warpgls (normalized between 0 and 1; warpage of 0 degrees is 1, warpage of 180 degrees is 0). The minimum of the 3 normalized diagnostics will be used.
josilver is offline   Reply With Quote
