[Gambit] Problem right-click
Old   March 30, 2010, 19:32
Default [Gambit] Problem right-click
gwenoul is on a distinguished road
I'm having troubles using Gambit. I would like to create a circle.
I know I have to right click on the "Create a face" button to choose the circle option but it's not working. When I right click on this button, the pointer of my mouse become reversed and I cannot change it and cannot click on anything. Everything is stuck! Then I have to use the Task Manager to close Gambit. Actually if I right-click on any button on Gambit, I'm getting the same problem.
Do you know what could the origin of this problem?
Thanks for your help.
gwenoul is offline   Reply With Quote
Old   May 18, 2010, 11:13
David
king198419 is on a distinguished road
Hi there,
Have you solved this problem yet? I have the same problem in Linux. Totally have no clue about it...
king198419 is offline   Reply With Quote
Old   July 18, 2010, 06:17
Default RMB problem (gambit)
msani is on a distinguished road
I found this trick by trial and error:
Press down and hold left mouse button on the menu button,
Now while keeping left button pressed down press down AND hold the right mouse button and you will see the hidden menu,
Keep down both mouse buttons and move the courser on the symbol of the command you need,
Now release both buttons at the same time and its chosen.
Unfortunately, I have not found any way to rescue gambit when it hangs by just right clicking on a menu button so I have to kill the process every time I forget the above procedure! Does anybody have a clue?
msani is offline   Reply With Quote
Old   September 27, 2010, 11:54
Costas K
thekay is on a distinguished road
Send a message via ICQ to thekay Send a message via MSN to thekay
I have the same problem. What msani said is the only solution to not having to kill gambit.
thekay is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
