[ICEM] Result of the meshing of a swirl injector
Like Tree1Likes
  • 1 Post By Far
Old   August 10, 2012, 12:50
Default Result of the meshing of a swirl injector
pipolaki is on a distinguished road
This topic follows this one : http://www.cfd-online.com/Forums/ans...-strategy.html
I have finished the mesh of my swirl injector and I want to share my results with you in order to receive your advice and your critics, especially concerning the quality of the mesh. I remind you that I'm new in ICEM so do not hesitate to give me basic advices if you think it would help me to improve my mesh.
The tin file is here :https://sites.google.com/site/alfred...edirects=0&d=1
1) First of all, you will find some views of my blocking strategy.
2) Then there is the mesh and a focus on one of the more critical area regarding the quality of the mesh.
3) At the end of the topic, you will find some quality graphs. I've heard on another topic that the most important criteria are the "angle", the "determinant" and the "orthogonality".
For the angle, it is advised that the angle MUST be over 9° and only some elements between 9° and 18° are accepted. The determinant MUST be over 0,1. I put the result for the skweness for information. What do you think of all this results ?
Thanks for your help.
pipolaki is offline   Reply With Quote
Old   August 10, 2012, 13:33
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I cannot see the pics...
pipolaki likes this.
Far is offline   Reply With Quote
Old   August 10, 2012, 13:43
Sorry. It should be OK now.
Old   August 11, 2012, 04:18
Far
Sijal
Your blocking seems very good.
I have some other quick ideas for blocking this geometry.
1. Model it as quarter model with two symmetries. Later on you copy/rotate to reproduce the exact symmetric 360 model as shown below.
2. Insert ogrid around the injector holes in the two circular regions between two concentric circles. Similarly inside the injector holes throughout the injector hole and into the circular region between two concentric circles (Fig 8)
3. I am struggling to put the quarter o-grid inside the small circular region which exits into the plenum through interface
What do you think about this approach?
Old   August 11, 2012, 13:42
Working with the symmetry function is a good idea because it's a way for me to discover a feature I don't know.
When I look on fig. 6, it seems there is interpenetration of blocks in the swirl chamber. Is it the case ? If yes, it can be a problem ?
Old   August 11, 2012, 14:12
Far
Sijal
Yes, there is penetration of blocks in swirl chamber. It is due to fact 180 deg block (square section ) in swirl chamber and I am unable to get the one quarter. So when copied all blocks to 90 deg and repeated twice to get the 360 model, I have duplicate blocks (180+180+180+180). It is to be noted that in all other blocks I get the 90 deg sector easily.
PS. After creation of main block, I have rotated it by 45 deg.
Comparison the airfoil 0012 experimental result and simulation result harrislcy FLUENT 30 August 29, 2013 10:27
swirlinjector az1362f OpenFOAM Running, Solving & CFD 59 June 12, 2012 22:42
[ANSYS Meshing] Meshing strategy for External Flows Hybrid ANSYS Meshing & Geometry 0 January 24, 2012 14:27
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Is conformal meshing really an advantage? Alvin Szeto Main CFD Forum 19 June 27, 2003 07:23
