[DesignModeler] How To Smooth 2D Surface
Like Tree1Likes
  • 1 Post By sac
Old   January 31, 2011, 18:47
Default How To Smooth 2D Surface
Ali
Ali_M is on a distinguished road
I made a 3D curve using a given set of points in DesignModeler, but when I came to create a surface from the curve, the edges of the surface did not match up with the 3D curve. I tried messing with it and found an option that would fix the discretized edges, but I can't seem to find the option anymore.
I've been looking through the help files and I still can't seem to find it. Can anyone help me with this issue? I'm afraid the 'non-smooth' surface will create issues when running the simulations.
I've attached a few pictures of the issues that I'm referring to. Thank you all in advance for your help.
- Ali
Ali_M is offline   Reply With Quote
Old   February 1, 2011, 20:56
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
That might just be a graphics issue, not a real gap. Just mesh it and see how it looks.
PSYMN is offline   Reply With Quote
Old   February 2, 2011, 04:50
sac
sac is on a distinguished road
It's probably the facetting control.
In DM go to the tools menu -> options -> graphics and then pick facet quality and set it to 10.
ykanani likes this.
sac is offline   Reply With Quote
Old   February 2, 2011, 05:20
AB
BrolY will become famous soon enough
You would face the same "issue" with all the others softwares.
You just need to be careful that the gap between the curves and the surface is lower than your smallest mesh element size (it's all about tolerance).
As Simon said, don't worry about it, and go for meshing!
BrolY is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Validation of surface roughness model approaching a hydraulically smooth surface jola CFX 1 October 20, 2010 10:06
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
