Cell element size
Old   January 19, 2011, 08:43
Default Cell element size
Bla Blubb
sys999 is on a distinguished road
I'm using Icem 12.1. Is it possible to display the exact Volume of a single mesh cell or to measure the length of a cell edge?
Thx
sys999 is offline   Reply With Quote
Old   January 30, 2011, 17:24
Default area and length
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes, there are quality metrics for many things including Volume/Area/Length.
If you put that element into a subset (right click on mesh=>Subsets=>Create and add elements to the subset) you can go to Edit Mesh => Display Mesh Quality, set the elements to check to your visible subset and set the quality criterion as desired (Volume, Max Side, Min Side or whatever)...
Note, you could also just use the measure tool (in the utility icons in the top left corner, second row, third column), but make sure you toggle on the selection tool bar option to allow mesh/block selection.
PSYMN is offline   Reply With Quote
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
