multiple curves in the iges file
Old   February 11, 2011, 01:00
Default multiple curves in the iges file
Shankar
shankar1221989 is on a distinguished road
I imported the DLR- wing body configuration iges file in icemcfd.
But once i import icemcfd is giving me coplanar curves, i.e two
curves lying in top of each other. It is also very difficult to manually
clean up, as every edge has one collinear edge.
Any suggestions on how to clean up?
shankar1221989 is offline   Reply With Quote
Old   February 11, 2011, 11:36
Default Build Topology...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes, easy (if you know where).
Geometry (tab) => Repair Geometry => Build Diagnostic topology.
Set the tolerance to something bigger than the distance beween the curves you want to remove, but smaller than the mesh size. (maybe 1/10th of the smallest mesh size to 1/2 the mesh size).
This will remove duplicate curves and surfaces, among many other things.
Look in the help for more on what Build Topology does.
Simon
PSYMN is offline   Reply With Quote
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
