Periodic boundaries
Old   February 17, 2011, 02:56
Default Periodic boundaries
kostas
pankos is on a distinguished road
Is there any way to make periodic mesh in gambit? With other words, the elements on a side to connect with elements of other side as there is continuity. Therefore in NEUTRAL file (which export the mesh) to not put boundary on this side but only nodes and connectivity.
pankos is offline   Reply With Quote
Old   February 17, 2011, 08:42
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
from Help:
NOTE: To apply a "periodic" boundary condition for use with a FLUENT solver, you must first create a mesh hard link between the pair of edges (2-D) or faces (3-D) to which the boundary condition is to apply. In addition, you must assign a PERIODIC boundary type to both edges (or faces) in the pair, and both edges (or faces) must constitute members of a single entity set.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 17, 2011, 10:13
kostas
No, i dont use FLUENT, but code which i made it. Due to i can take mesh information only by ASCII neutral file (Generic).
If i select Generic at solver menou , it doesnt appear any periodic boundary at Boundaries.
For example, on two opposite sides of rectangular to there are the same nodes (number node) so that to appear that there is continuity.
Old   February 18, 2011, 01:09
-mAx-'s Avatar
Maxime Perelli
Then I don't know but I would respect the hard link between your periodic surfaces: each periodic surface shouldhave exactly same mesh.
Define them as separated BC and assign as element size.
After that you will be able to pick those surfaces and apply BC with your code
Old   February 18, 2011, 02:14
kostas
Ok. As shown, the only way is this. It must be construct only by code.
But, if in connectivity list of elements which derived by Mesh generator, has same number (indexing )of nodes at two face then two faces will be periodic. Of course, here, there is a problem. The two faces are dif topologies,therefore it can not be have same coordinates of nodes.
Thanks.
Old   February 18, 2011, 02:19
-mAx-'s Avatar
Maxime Perelli
if your surfaces don't have same topology, are they still periodic?
Old   February 18, 2011, 05:59
kostas
yes. The continuity of a side is other side. i dant know, i wiil try to make this in my code but of course without any generallity.
Old   February 19, 2011, 13:27
Default Make Periodic...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Is you problem generating a mesh with corresponding periodic nodes? Or is the problem that Fluent just doesn't give you the opportunity to apply a periodic boco (the Periodic Conditions button is not available)?
If it is the latter, make sure that each side has its own separate boundary condition name (like Per1 and Per2). Then, via the command prompt (type
define/ boundary-conditions/ modify-zones/ make-periodic>
This causes Per1 and Per2 to merge into a single periodic boundary condition and the "Periodic Conditions" button becomes available for further settings.
PSYMN is offline   Reply With Quote
Old   February 20, 2011, 05:37
kostas
All periodic conditions are problems of solver and not Mesh generator. Simply, the mesh generator determine the edges which have Periodic B.C.
If was problem of mesh generator must be put tha same nodes (index of node) at the periodic edges so that appear as continuity. Of course, the coordinates of these nodes is not determined clearly because belong to different edges. Therefore, as output file must be export the connectivity list (doing the consideration that the nodes of Edges of P.B.C are same) and for coordinates of nodes (doing consideration that these nodes are different).
periodic boundaries Mary FLUENT 27 January 6, 2021 01:54
CGNS import in fluent - periodic boundaries. Bjarne Břrresen FLUENT 2 April 25, 2013 11:12
Why can't I make the boundaries periodic? Alina FLUENT 5 April 12, 2012 14:06
periodic boundaries - flow through a net PK FLUENT 0 July 12, 2007 11:58
Periodic Boundaries in GAMBIT!! swetha FLUENT 1 November 26, 2006 22:02
