non-convex cells in ICEM 12.0
Like Tree1Likes
  • 1 Post By PSYMN
Old   February 23, 2011, 11:16
Default non-convex cells in ICEM 12.0
DaIN is on a distinguished road
Hi there,
I'm trying to create a mesh to be converted into KIVA 3V mesh file.
After creating the geometry, blocking, association and meshing I finally got a mesh which looks apparently fine. Please look at the picture.
I checked the Quality Histograms and I obtained volume > 0 for all cells which I guess it's the mean condition for a mesh to be used in KIVA.
But, after running the code I got an error message saying I have non-convex cells.
I could find out though, these non-convex cells are located around the axis, but there's no way for me to get rid of them.
Does anyone know how to do that??
Thanks a lot,
daniel
DaIN is offline   Reply With Quote
Old   February 23, 2011, 11:23
Ludvik is on a distinguished road
http://homepages.cae.wisc.edu/~hesse...rialIntro.html
Ludvik is offline   Reply With Quote
Old   February 23, 2011, 11:35
Thanks a lot for your answer, but that's the tutorial I've been mainly following.
My geomtry is also different in a sense that I don't have periodic faces, but I do have an axis which must be setup as periodic.
It does not say anything about non-convex cells...
daniel
Old   February 24, 2011, 11:57
Default Wedges or collapsed Hexas?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Are those wedges along the center axis or are they collapsed hexas (perhaps that is your problem). You can tell quickly with a mesh summary or simply by looking at the mesh/volume branch of the tree. Do you see any penta-6 or prism elements?
I am not sure what a periodic axis is, but have you considered an Ogird instead of wedges in the middle?
rostamis likes this.
PSYMN is offline   Reply With Quote
Old   February 24, 2011, 12:26
The non-convex cells (wedges??) are not along the axis, are near the axis, actually around it (I didn't check them all, there are 144) and i reckon they might have collapsed somehow. I can't see those kinds of cells in the mesh, but honestly I'm not sure if i'd be able to recognise them if the exist, becase I don't know how they look like. Is there anyway I can fix them?
About periodic axes I meant that i defined the bottom and top points of the axis with 360 degrees of periodicity, but I did not use more periodic conditions in the mesh.
Thanks a lot indeed for your help on this,
daniel
Old   February 24, 2011, 15:51
Oh sorry I forgot to mention it.
I did use O-grids, actually I used two. The first one is for the annular outer region and the second one is for the circular inner region. The problem is that as i will export the file into KIVA format, I think I canīt use O-grids due to the local axis of the blocks. For that reason, i always remove the inner block which never can get aligned with the others.
Thanks a lot,
daniel
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
