error IN ICEM CFD V.12.0.1
Old   February 23, 2011, 13:14
Default error IN ICEM CFD V.12.0.1
MASOUD
MASOUD is on a distinguished road
While saving the generated 3D mesh, the attached error happened. What would be the possible source of this error?
Thanks
MASOUD is offline   Reply With Quote
Old   February 23, 2011, 13:20
MASOUD
I attached it here.
Old   February 24, 2011, 12:04
Default Write 7-node-hexas as pyramids
PSYMN's Avatar
Simon Pereira
Somewhere in your model, you have a hexa element with one edge pinched to form a 7 noded hexa. ICEM CFD is flexible and doesn't mind, but Fluent does, so ICEM CFD lets you know about this problem during output.
You can check your blocking and sort this out (maybe you shouldn't have any of these). If your topology actually requires this sort of collapsed edge (typical near the tip of flow around cones in a periodic model), you could upgrade to a newer version of ICEM CFD that has an option under "settings => Hexa/Mixed" that will auto convert 7 noded hexas into pairs of pyramids that Fluent will support.
This screen shot is from 13.0, but I forget when it was added.
[ICEM] Icem CFD on Linux mechanicaldesign ANSYS Meshing & Geometry 7 March 11, 2021 19:44
Need help icem cfd kakhtar ANSYS Meshing & Geometry 25 January 31, 2017 01:09
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
Importing Solidworks part into ICEM CFD MetalSupremacist FLUENT 0 October 8, 2010 17:46
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
