[ICEM] Merging Hexa Meshes in ICEM
Like Tree1Likes
  • 1 Post By BrolY
Old   April 7, 2011, 20:21
Default Merging Hexa Meshes in ICEM
Martin
screech1987 is on a distinguished road
To model an aerodynamic body I have made the flow domain out of three seperate blockings. One being the majoirty of the flow, being rotated from a 2D blocking.
Then to improve quality in the centre of this freestream region, eradicating wedge shaped cells, I blocked this 'core' separately using a 3D O-Grid.
Now I have come to merge them, by loading in the separate blockings and merging the topologies by using the merge option by right-clicking on the blocking 'tree'.
The end result is essentially what I want but with the following problems:
1) Non-Manifold Vertices and Multiple Edges are detected during mesh checking. I assume this is due to there being two surface meshes at the blocking interfaces? If so how do I merge the meshes completely/fix the problem.
2) More of a preference, but is there a way to make the merged blockings output a mesh as a single region, i.e. the surface meshes found at the interfaces between the separate blockings are not produced.
Thanks in advance,
Martin
screech1987 is offline   Reply With Quote
Old   April 8, 2011, 02:08
jeevan kumar
jeevankumarb is on a distinguished road
if you post some images it will be much more clear to understand.
Thank you
jeevankumarb is offline   Reply With Quote
Old   April 8, 2011, 07:39
AB
BrolY will become famous soon enough
For your first point, associate all your curves with the edges at the interfaces of your 2 mesh. I guess you are looking for a conformal merge, so you must have the same number of nodes on each edges of your interface, and the same node repartition.
As jeevankumarb said, pictures would help !
AlexRonto likes this.
BrolY is offline   Reply With Quote
Old   April 8, 2011, 07:53
Martin
Sorry, will try to upload some pics as soon as, just not in front of my normal PC today.
With regards to the assigning to curves and mesh spacings. I have associated the both interface edges to the same curves where relevant. Also have checked the number of nodes and spacings are the same on each edge before merge. and also after. The merged mesh looks as if the nodes are conforming across the interfaces matching up.
Old   April 8, 2011, 08:03
AB
I have juste re-read your first topic : have you tried to merge your blocking ??
You should convert your 2 meshes to "unstructured mesh", and then do the merging (merge nodes with an adequate tolerance, deelte the 2 interfaces). I think it should be better.
Old   April 8, 2011, 09:06
Default Remove Association to Surface...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
It sounds to me like you are saying the merge worked (you had matching topologies and you merged all the verts). It is not actually necessary to match edge distributions as that is taken care of automatically...
So the remaining issue is that you have the interface faces still projected to something...
1) Check that the blocks in all three sections are in the same blocking material (like FLUID). If not, and you have different volume zones on purpose, your solver will want shells, even if they are later marked as internal walls.
2) If you are sure that you don't want/need internal shells, just go into Blocking => Associations and delete the association on those faces... Without association to surface, no shells will form.
Best regards,
Simon
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   April 8, 2011, 13:13
Martin
Thankyou for the replies so far.
I have attached some pictures as requested. A geometry Screen grab, A blocking screen grab, and a second blocking pic zoomed in on the hexa core.
Follwing on form the sugestions made, I created a body, and reset appropriate asscoaitions.
However, when creating a new body, i attempted to delete all previous ones, but none were present, so went ahead and defined one anyway.
Furthermore when restting associations I noticed duplications of blocking edges in the interface locations. I assume this is the cause of the errors encountered above in the previous post.
Also to note the resetting of associations and a new body did not solve my shell mesh at interfaces problem.
Cheers,
Martin
Old   April 8, 2011, 13:19
Martin
A couple more screen grabs of resulting mesh, and shells at interface and a region showing the duplicate edges (hard to tell)
Old   August 24, 2012, 02:34
Fabian E.
galap is on a distinguished road
I have struggeld the last days trying to merge two hexa meshes having the same node distribution at the interface plane. PSYMN suggestion was helpful regarding the face issue but it was not the solution for the uncovered faces issue.
What I have done now:
I deleted the face associations at the interface section
then
Edit Mesh -> Check Mesh -> Uncovered Face -> found elements in subset
only visible elements in this subset -> Edit Mesh -> Merge Nodes by Tolerance -> set in a proper tolerance -> Apply
Edit Mesh -> Check Mesh -> Fix duplicate elements
that worked perfect for me!
PSYMN, If you read this: In the ansys support section there is a FAQ regarding the merge of two hexa meshes using "Merge volume meshes". I think you should distinguish between conform and not conform meshes.. No one wants pyramid elements when you work with conform meshes.
galap is offline   Reply With Quote
Old   August 28, 2012, 02:18
Ozge
ozgulo is on a distinguished road
did you try t-merge? it is a utility of fluent. if you have two seperate mesh files with nearly the same distribution on the interface, and they are unstructured (i mean mesh method is unstructured not tetras), you can merge them with t-merge as far as i know.
ozgulo is offline   Reply With Quote
Old   August 28, 2012, 02:22
Fabian E.
No I haven't, but now I have spoken with ANSYS support. The usual way is to merge different topologies. You do this in your blocking tree. Right click on root topology -> Merge. Blockings have to be in the same part.
Works perfect for me!
Old   March 13, 2014, 11:45
Default help me to mesh shell block geometry in icem
  #12
hemant ghule
hemant.ghule is on a distinguished road
hemant.ghule is offline   Reply With Quote
blocking, hexa, icem, merge, structured mesh
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 06:50
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 19 March 31, 2016 02:33
Different results from similar quality cfx and ICEM meshes Nick R CFX 3 January 17, 2011 07:48
Hexa meshes with ICEM CFD 5.1 Tim Guo CFX 8 June 29, 2005 09:27
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 06:46
