April 22, 2011, 00:44 |
Meshing after geometry changed
Ran.Duan
Rep Power: 15 |
I need to change the geometry of my model to make comparisons,but meshing cost to much time. I wonder if I could finish the work more efficiently with any function of ICEM?
April 25, 2011, 03:56 |
Rep Power: 16 |
Are you using a structured or unstructured mesh?
Also is your mesh multi-block? |
April 25, 2011, 06:34 |
Ran.Duan
Rep Power: 15 |
Thanks for your reply.
I use structured mesh and only hexa block. |
April 25, 2011, 06:40 |
Rep Power: 16 |
Replay Option: Replay file functionality enables parametric block topology generation linked to parametric changes in geometry
This will help you in case the blocking was taking time, if however the actual mesh generation from the blocking is taking time, I don't know what will reduce that time. |
April 25, 2011, 06:53 |
Rep Power: 16 |
If the mesh generation process itself is taking time you can use mutli-block strategy so that you only have to generate the mesh in that block only. Also for parametric studies you can use the update vertices option so that you do not need to bother about blocking. Hope this helps. |
April 25, 2011, 08:39 |
Ran.Duan
Rep Power: 15 |
Thank you very much!
It helps a lot. |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
Need help on meshing this simple geometry | nha1g08 | ANSYS Meshing & Geometry | 3 | March 9, 2011 02:13 |
[blockMesh] error Meshing a 3D cube geometry with blockMesh | GodOfLove | OpenFOAM Meshing & Mesh Conversion | 5 | July 14, 2009 15:30 |
Problem meshing turb. blade tip clearance geometry | Balu | FLUENT | 0 | June 7, 2008 21:10 |
meshing geometry in gambit | soundar | FLUENT | 1 | January 7, 2005 02:59 |
