[ICEM] Modelling Of Butterfly Valve
Old   April 25, 2011, 08:23
Default Modelling Of Butterfly Valve
Melih Meriç
mmntmflx is on a distinguished road
Hi, My friend,
Firstly, welcome to all of you.
I am starter position in cfd & meshing procedure and i started a industrial project as graduate thesis..
Longterm we will study FSI, but i have to make presentation about a litte part of this study. I have to mesh butterfly valve + pipe system.
Since i'm new this area, i dont know how i take a real/good mesh in this system. i tried many of time, but my geometry is complex.
can anyone gelp me? can anyone take mesh for me?
if you do this, please explain step by step that you make assumptions or techniques. this can be goog start for me.
thank you cfd_online.
Last edited by mmntmflx; April 25, 2011 at 08:48. Reason: dear mods, please delete this message
mmntmflx is offline   Reply With Quote
Old   April 28, 2011, 07:49
Dhananjay B. Deshmukh
dhananjay1287 is on a distinguished road
attach some images of your fluid domain .
otherwise could not explain the procedure.
also which tool u r using for meshing.
(i am good in ICEM and gambit only)
dhananjay1287 is offline   Reply With Quote
Old   April 28, 2011, 09:36
Melih Meriç
Hi Dhanajay,
I made a mistake previously and first message (actually this message), I posted two times this message, in previously forum menu, you can see other message in this situation from me. In that message, i gave parasolid file and an image about my problem.
Again if you look there, you can see one butterfly valve and long pipe on both side.
pipe + valve + pipe system,
i will make a FSI analysis finally but firstly i would like to learn meshing, and i want to learn icem cfd absolutely in the level of expert..(long term goal).
if you can help with meshing this system, i am very glad.. problem is internal flow.. and i would like to take volume mesh in this system (which mesh type we use, and why?)
http://hotfile.com/dl/115746645/554af92/mesh.jpg.html screen shot
http://hotfile.com/dl/115746241/ccea...valve.x_t.html parasolid file
Old   April 29, 2011, 03:30
First of all,
1. Extract the fluid volume.
meaning deleat all the surfaces which are not in contact with fluid.
do splitting operations if u have to.
2. Creat inlet and outlet put them in different parts.
3. Make body point in fluid doman.
4. Do tet mesh with roboust octree method.
This is the simplest method.
I hhope this is helpful
Old   April 29, 2011, 11:06
Melih Meriç
Originally Posted by dhananjay1287 View Post
First of all,
Dear Dhanajay,
thank you for your help, now i'm in business. when i go to home, i try the step that you offer. now ,i guess, i understood the process that you said.
1. i will delete all surfaces except for cylinder inner surface and i will define fluid volume passing throuhg the pipe.
2. inlet and outlet surface of pipe geometry must be separate surfaces from left down menu in icem cfd screen. to create inlet and outlet..
3. how i define body point in fluid domain? and where? somewhere in pipe axis? or anywhere in fluid domain?
4. after first three steps we will make a tet mesh from icem automaticly, but why tet mesh? cant be hexa? or prism? what is the trick here?
which mesh type occures better solution for me?
you wrote that very helpful for me, thank again. after try you wrote again i will come back to this topic and give my results and possible problems.
Moving mesh with butterfly valve uorinopuot CFX 16 February 25, 2011 05:40
butterfly valve euzinho FLUENT 0 May 28, 2010 08:58
Areodynamic torque of butterfly valve J.Szary CFX 9 October 13, 2008 17:51
butterfly valve C. K. Main CFD Forum 1 April 2, 2006 23:30
ask help on valve flow simulation(3D modelling) Anna FLUENT 0 July 18, 2003 17:39
