July 1, 2013, 07:31 |
merging surfaces problem
Hi experts.
I've got a geometry with several surfaces beside each other which have their own curvature radius at the end. When I try to merge them they don't fit in to their boundaries and some tiny holes are made. Repair geometry can not fix them. it doesn't detect the holes. How can I fix them? thanks in advance |
July 1, 2013, 10:36 |
Best fix is to run octree, repair mesh (as tools of mesh edit are more powerful) and delete underlying geometry. Create geometry from the created mesh and you are done (Tips by Simon)
July 1, 2013, 12:27 |
Answer
Hi mate,
Maybe holes are just visual. Try decreasing Tri tolerance. Just search in forum "tri tolerance" and you get it.
ICEM, CFX and Fluent expert |
July 4, 2013, 07:24 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
Problem with tet-tet mesh merging (ICEM) | srr | ANSYS Meshing & Geometry | 6 | December 26, 2010 11:13 |
BladeGen: problem with periodic surfaces | famarcfd | ANSYS Meshing & Geometry | 0 | December 7, 2010 10:51 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
Multiple Sahdows / Periodicity Problem | Michael Pi | FLUENT | 0 | July 11, 2005 07:42 |
