[GAMBIT] Stairstep meshing in Gambit
Old   November 14, 2012, 09:45
zaynah K.
zaynah04 is on a distinguished road
yes i want to.
zaynah04 is offline   Reply With Quote
Old   November 15, 2012, 01:51
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
only one size function................
The only problem is between faces 133 & 139 (a combination of split and connect should fix the issue)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 15, 2012, 04:11
zaynah K.
hi..
did as you told and got that error
"mesh of face.334 contain 1 highly skewed element"
Old   November 15, 2012, 04:14
-mAx-'s Avatar
Maxime Perelli
what are your parameters for your size fonction?
Old   November 15, 2012, 04:21
zaynah K.
tet/hybrid, tgrid and 10
Old   November 15, 2012, 04:25
-mAx-'s Avatar
Maxime Perelli
http://aerojet.engr.ucdavis.edu/gamb...ommands_create
I used tet/Hexcore
http://aerojet.engr.ucdavis.edu/gamb...chemes_hexcore
Old   November 15, 2012, 04:35
zaynah K.
sorry i misread.
0.03
1.3
1
Old   November 15, 2012, 04:51
-mAx-'s Avatar
Maxime Perelli
I used
1
1.2
20
Old   November 26, 2012, 05:05
zaynah K.
hi
did you mesh the faces first?
and my PC is quad core with 16 Gb of ram..i still can not mesh it.
Old   November 26, 2012, 05:08
-mAx-'s Avatar
Maxime Perelli
If I meshed the surface then it is only building's surfaces.
What kind of error do you receive?
Old   November 26, 2012, 05:13
zaynah K.
volume cannt be meshed without faces sucessfully meshed
Old   November 26, 2012, 06:04
-mAx-'s Avatar
Maxime Perelli
then you have skewed cells for sure, check where I pointed out (post #22)
Old   November 26, 2012, 09:08
zaynah K.
i did of course as you recommended for in post#22...
still it says i have skewed elements...
sometimes it meshes then all freeze and i have to start again..
Old   November 26, 2012, 09:28
-mAx-'s Avatar
Maxime Perelli
go to examine mesh and check where are those cells.
Old   December 6, 2012, 05:38
zaynah K.
dear max,
after i split n connect faces. i then mesh the faces using tri pave
then i mesh the volume.
attachd is the error i found.
can you please enlighten me ?
cheers
Old   December 6, 2012, 05:57
zaynah K.
hi
what to do when we have highly skewed elements? it say my mesh has 63 highly skewed elements...;(
thanks
Old   December 6, 2012, 06:54
-mAx-'s Avatar
Maxime Perelli
fix those skewed elements.
First, check where they are, and try to find any topology which is responsible for the skewness
Old   February 20, 2013, 06:37
Default Gambit size function problem!
  #38
Kanarya is on a distinguished road
I am trying to use two size function together but it seems doesnt work. my geometry is 3D I would like to have dense mesh y+=1 near the wall and at the same time to have coarser mesh in flow direction. it it seems like I am getting dense mesh near the wall but I got same mesh size in direction of flow. the other problem is gambit giving me problem with the memory!
thanks in advance!
Kanarya is offline   Reply With Quote
Old   February 20, 2013, 08:14
-mAx-'s Avatar
Maxime Perelli
what parameters did you give for size function?
Old   February 20, 2013, 09:01
Hi max,
thanks for quick answer!
my geometry is 170 1500 190 in mm. first size function is 1 to 3 with growthrate 1.2. and y direction 3 to 8 with same growthrate.
thanks in advance!!!
[ANSYS Meshing] ANSYS Meshing vs GAMBIT aerospain ANSYS Meshing & Geometry 0 September 28, 2011 06:05
Gambit meshing error jx FLUENT 11 May 26, 2009 10:35
GAMBIT problem with 3D Boundary Layer when meshing Anthony Haroutunian FLUENT 2 March 26, 2008 02:02
meshing a fan using gambit tony FLUENT 1 February 15, 2008 00:28
Gambit: too long meshing time! delsolman FLUENT 1 January 29, 2008 19:06
