[ANSYS Meshing] Negative Cell Volumes
Old   June 14, 2011, 04:05
Default Negative Cell Volumes
donkey86 is on a distinguished road
Hi there!
I am still trying to mesh a pipe with a radial inlet. Running quality checks
I get negative cell volumes on most of the edges. I tried adapting the spacing and ratio values but still no improvement. The associations of edges and vertices look fine as far as I know. Can somebody help me please?
donkey86 is offline   Reply With Quote
Old   June 14, 2011, 04:09
there you have a screenshot
Old   June 14, 2011, 06:33
Christa
user_of_cfx is on a distinguished road
I can't see the cross-section very well, are you using an O grid? It seems that where the inlet is the mesh gets unusually distorted, or maybe it's the angle with which I'm looking at it. Usually an O-grid will solve most of the problems near the edges. If the distortion I see is where the negative quality elements are, then this is a tell-tale sign that an O-grid is needed.
If you do have an O-grid and still get this, how did you create your geometry? Sometimes trying a different approach to get the same geometry solves some problems.
Hope it helps.
user_of_cfx is offline   Reply With Quote
Old   June 16, 2011, 02:26
thanks for your help, I tweaked the geometry and solved my problems. now there is a smal amount of cells left, but I i am hopefull to get rid of them soon.
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
