[ICEM] Meshing of a cylinder containing a small hole on one face |
March 9, 2014, 06:39 |
Giovanni
Hello people,
I am new to ICEM and I am facing the following problem: I have to mesh a cylinder with a small opening at one face in order to simulate a bubble column within an air-lifting reactor. In order to do that, I created a big cylinder and small circle near one of the two faces. Afterwards, I projected the circle on one of the faces of the cylinder, then I trimmed the big face with the projected circle, and finally I created two surfaces. I did all the tutorials of the tutorial manual but I have still no idea how to do that . I would like to create a structured mesh if it is possible. The dimensions of the big cylinder are: Height 50 cm, Diameter 5 cm. The diameter of the small circle is 1 mm. I do not think that it is difficult, but I don't know how to do that. Can anybody help me? |
August 12, 2015, 06:49 |
surya
Rep Power: 10 |
if you have solved this problem can you explain
cylinder structured mesh |
[ANSYS Meshing] Mapped Face meshing | Thermal_engg | ANSYS Meshing & Geometry | 4 | June 5, 2013 05:37 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
2D planar cylinder meshing problem | saisanthoshm88 | ANSYS Meshing & Geometry | 15 | December 27, 2010 11:14 |
[ICEM] (ICEM CFD) meshing over a cylinder | vmlxb6 | ANSYS Meshing & Geometry | 6 | August 11, 2010 14:37 |
small cylinder and big cylinder | Eric | CFX | 1 | January 26, 2007 05:38 |
