ICEM-CFD
Old   June 30, 2006, 03:06
Default ICEM-CFD
Antonis
Does anyone know what 'segmentation violation' means in ICEM-CFD? I get that message when I try to create the input files for the solver I'm using.
Thanks,
Antonis
Old   June 30, 2006, 14:28
Default Re: ICEM-CFD
pc
Segmentation violation for any program means a memory fault. Accessing beyond the limits of an array, accessing an array that's not allocated, etc.
Old   July 22, 2006, 03:01
vishal
Hi, Segmentation violation means crash.It means the code behind that command is stucked/disturbed.
-Vishal
Old   April 6, 2011, 02:28
Default regarding segmantation violation error
Raju
Raju is on a distinguished road
hi,
i am getting always an error that segmantation violation when i opened icem.
how can i rectify that problem.
please reply if you know.
Raju is offline   Reply With Quote
Old   April 6, 2011, 18:37
Martin
screech1987 is on a distinguished road
Depending on whether you are using ICEM off a server or based on a single machine could be something to due with insufficient memory or file access.
Get it sometimes when I am using it on big meshes and doing lots of dynamic zooming in and outs while its processing a change.
screech1987 is offline   Reply With Quote
Old   June 21, 2011, 15:52
Robert
Robert@cfd is on a distinguished road
Hi there
I am getting 'segmentation violation' when I try to convert my Pre-Mesh to Multiblock Mesh. It should not be a memory fault, because I tried it with a small mesh and even on a machine with 32GB RAM. I tried it on a Windows and a Linux machine.
I am using ICEM 12.1.
Is it possible that the geometry/blocking is the reason for the problem? Or do you guys have some other hints for me?
I appreciate any effort.
Thx, Robert
Robert@cfd is offline   Reply With Quote
Old   June 22, 2011, 10:22
Robert
Hi
Maybe the replay-function is the problem. I sometimes get weird errors when I am loading a replay-file. Also I cant replay my commands from the beginning to the end. I dont know why this is happening.
I tried building my mesh on ICEM 11.0 without using the replay-function. This time I can create the Multiblock Mesh but I get an error writing the data out (Output/Write Input).
 Running ICEM CFD/CAE Multi-block Info Vers. 5.0.0
Error in unsh_gsfdims, idomnum=2
Error exit in unsh_gsfdims
Error creating multi-block neutral files...
child process exited abnormally
Done
Done with translation.
I am using Multiblock-info / Nastran solver. It seems that the .dom files were created correctly, but the .topo file isnt complete.
Old   June 24, 2011, 05:41
Default segementation violation
Raju
Segmentatiion violation error means: it may be geometry size problem or you are not having licence to access.
-raju
Old   June 24, 2011, 08:57
Robert
Hi Raju, thx for your reply.
What does "geometry size problem" mean? Is it that my workstation is too weak (RAM, HDD, CPU) to handle the mesh? I dont think thats the problem.
Thx for the hint with the licencing, we are having a change because of ANSYS 13 and therefore I have problems with the ICEM OUT licence. Maybe there is another problem concerning the creation of the mesh files.
[ICEM] Icem CFD on Linux mechanicaldesign ANSYS Meshing & Geometry 7 March 11, 2021 19:44
Need help icem cfd kakhtar ANSYS Meshing & Geometry 25 January 31, 2017 01:09
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
Importing Solidworks part into ICEM CFD MetalSupremacist FLUENT 0 October 8, 2010 17:46
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
