Multi-element airfoil meshing
Old   June 24, 2011, 14:13
Default Multi-element airfoil meshing
jose antonio is on a distinguished road
Hello, I am trying to mesh a multi-element airfoil with fully unstructured with tetra mesh, the problem that I have is that at the trailing edge it seems like if there would be a leakage of the mesh inside of the airfoil. The distance between the upper line and the lower line of the airfoil at the trailing edge is really small so I do not know if that has some influence. Another thing that I have found when I did the mesh is that in the model tree in the mesh part the lines and the curves in geometry do not match one to the others and where they do not match is where the leakage appears, I would be really thankful if someone could help me with that.
Also I would like to say that a video tutorial like the hexa on youtube about how to do a hybrid mesh using the 2d Blayer could be really useful for lot of people.
Thank you very much.
jose antonio is offline   Reply With Quote
Old   June 27, 2011, 02:55
jeevan kumar
jeevankumarb is on a distinguished road
if you can upload some images, it will be easy to understand.
jeevankumarb is offline   Reply With Quote
Old   June 28, 2011, 05:25
Here you can see what is happening to me, the elements cannot represent properly the geometry, I don't know if this is because any kind of tolerance of because of the size of the element. That mesh is patch dependent mesh. Thank you
Problem running simpleFoam on a multi element airfoil vinz OpenFOAM Running, Solving & CFD 18 April 11, 2013 11:26
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 00:43
Question about reference values --> Area (multi element wing) Zweeper FLUENT 7 March 28, 2010 11:29
multi element airfoil data shadi memarpour Main CFD Forum 0 June 20, 2004 04:33
Multi Element Airfoil J.Dumas Main CFD Forum 2 May 13, 2000 07:24
