[ICEM] Formatted point data issue
Old   August 4, 2011, 07:57
Default Formatted point data issue
Gon
gontxo is on a distinguished road
Iīve been reading every post related to importing coordinates to either icem or design modeler. However, I havenīt solved my problem at all.
I followed the format given in icemīs help to import points, and I always get a "nothing visible" text line, and no geometry is showed.
Please Iīm trying to do my thesis simulating flow around an airfoil and I canīt start because of this, if someone could send me a valid file with coordinates I think could be enough.
Thank you
gontxo is offline   Reply With Quote
Old   August 11, 2011, 18:24
Prakash Paudel
Prakash.Paudel is on a distinguished road
sounds like you need to check points, curves and surfaces under Geometry in model tree
Prakash.Paudel is offline   Reply With Quote
matching variable data with grid point data anfho OpenFOAM Programming & Development 0 May 6, 2011 15:28
How to put melting point data of inert particle in DPM model of Fluent subhankar_bhandari FLUENT 0 July 28, 2010 07:40
How to put melting Point data of inert particle in DPM model subhankar_bhandari Main CFD Forum 0 July 26, 2010 07:28
Point cloud data ms Main CFD Forum 1 July 25, 2006 16:54
Passing point data to UDF using C_UDMI Sam Bennett FLUENT 6 December 1, 2005 08:46
