fine mesh in wake trailing edge
Old   June 29, 2011, 11:13
Default fine mesh in wake trailing edge
jose antonio is on a distinguished road
hello, how could I do a finer mesh in the wake zone after the triling edge of a 2d airfoil using patch independen mesh with tetra elements? I have tried using densyties but the result is not very good. Also I don't know how can I control the ratio of growth, what I have done is set the curve parameters and the max element in the global meshing settings but the ratio of growth in the surface mesh is very abrupt.
And how can I do the same with patch independent?
Thank you in advance.
jose antonio is offline   Reply With Quote
Old   August 11, 2011, 19:10
Prakash Paudel
Prakash.Paudel is on a distinguished road
try extending the trailing edge vertex to make a curve that extends up to the Farfield or somewhere in between
Prakash.Paudel is offline   Reply With Quote
[ICEM] Improve prism mesh at trailing edge siw ANSYS Meshing & Geometry 5 August 20, 2011 23:56
How to refine the mesh near the Trailing Edge in TurboGrid BalanceChen CFX 0 March 3, 2011 03:53
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
