[ICEM] TCL scripting error (parameter use in functions)
Old   July 25, 2011, 05:46
Default [ICEM] TCL scripting error (parameter use in functions)
firesoul is on a distinguished road
I'm having a problem using parameters in Icem's geometry functions. I'm trying to create points on a curve having a distance of 0.05 of the curves length.
No problem by using the command with an actual number:
# Create Point+Curve
ic_point {} SPLINE pnt.01 0,0,0
ic_point {} SPLINE pnt.02 1,0,0
ic_curve point SPLINE crv.01 {pnt.01 pnt.02}
# Create point on curve at position 0.05
ic_point crv_par SPLINE pnt.03 {crv.01 0.05}
I'd like now to replace the number by a parameter, which may be used in a loop:
# set point number and start param
set pnt_nr 3
set param 0.0
#---Loop Start
# Set the parameter to create the point; output of correct value
set param [expr {$param+0.05}]
mess "set param  to: $param \n"
ic_point crv_par GEOM pnt.$pnt_nr {crv.01  $param}
incr pnt_nr
#---Loop End
I get the following error
Error in replay of ic_point crv_par GEOM pnt.$pnt_nr {crv.01  $param}:
{Error in scanning curve parameter: $param}
I figured I had the wrong format so I tried several approaches to get it to work, without success.
{expr $param}
[$param]
"$param"
Thanks for any Ideas on how to get it working!
File Type: txt param.txt (497 Bytes, 20 views)
firesoul is offline   Reply With Quote
Old   July 25, 2011, 11:55
fox000002's Avatar
fox000002 is on a distinguished road
{crv.01 0.05} is a list.
No substitutions are performed on the characters between the braces here.
Use list operations to construct the list variable.
set crvl {crv.01}
lappend crvl $param
ic_point crv_par GEOM pnt.$pnt_nr $crvl
fox000002 is offline   Reply With Quote
Old   July 25, 2011, 12:36
Good to know that these functions work with lists. Thanks fox!
icem tcl script parameter
[ICEM] What are sub-loops and help my failing mesh. siw ANSYS Meshing & Geometry 3 March 13, 2010 07:18
