July 29, 2011, 09:52 |
Edge association to curved curves
Max
I'm doing a block-meshes for a flow in curved channels and I'm having the same problem over and over again. I associate the edges to the curved curves and sometimes the mesh does not really adapt to the curve. I usually try to solve this problem by additionally association the faces to surfaces, vertices to points and so on... But that does not always work out. I attached a screenshot as an example. Can somebody tell me what I am doing wrong? Thanks in Advance! |
August 1, 2011, 04:06 |
Max
Here is some more information:
I'm using ICEM CFD 13. The geoemtry is imported via WorkBench Reader from SolidWorks. But I deleted and created several geometry items in ICEM and it did not change anything. |
August 4, 2011, 09:20 |
Max
I still do not have a solution for this problem.
If there is somebody has the time to look over my blocking, i would be happy to send you my ICEM project files. |
March 3, 2017, 04:51 |
Rep Power: 9 |
did you ever find the solution to this? I think i'm having the same problem (in 2D) |
March 3, 2017, 10:49 |
Max
I actually don't remember anymore but I'm sure it was my own fault. Did you snap the vertices after associating the curves?
Edges association in ICEM | Santiago Orrego. | CFX | 10 | July 26, 2020 11:45 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
[Commercial meshers] Star mesh import problem | chris1980 | OpenFOAM Meshing & Mesh Conversion | 20 | May 8, 2006 01:07 |
