[GAMBIT] axis Boundary conditions
Old   September 4, 2011, 03:03
Default axis Boundary conditions
sofia
sofie1 is on a distinguished road
Hi
I need some help,how can i define the axis when it is out of domain in case of 2D annular flow in circular duct it is axsi symetric and the only mesh(annular domain ) is importes in fluent how can i do???
sofie1 is offline   Reply With Quote
Old   September 5, 2011, 02:09
-mAx-'s Avatar
Maxime Perelli
good question...
*Did you try to import your mesh in the 2d-axisymetric solver?Check your solver's specifications for axis BC (for instance in Fluent it has to be x>0 and your domain should belong to xy postive quarter (x&y>0))
In this case if your domain is in (xy)>0 and no cells at y=0, maybe fluent will automatically treat it right (go and display your grid with symmetries to check if Fluent reflects your grid around x)
*I never tried it, but you can also try that: in 2d you can mesh a solid domain in which your axis will be meshed. Define the solid region as solid and export
*Else you can try a workaround by switching in 3d and using symmetries.
Old   September 6, 2011, 02:42
sofia
thank you-mAx-
I think ,i'll try the second case with meshing the solid domain,i tried with importing mesh in the 2d-axisymetric solver but the results were wrong.
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 11:55
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Fluent accuracy and boundary conditions Paolo Lampitella FLUENT 0 June 12, 2008 06:25
